Siemens S7 315 < serial comm > Allen Bradley ControlLogix 5561
Jonesy_55
Jan 2010
Minnesota
If you were to set up serial communications to pass data back and forth between a Siemens S7 315 Processor and an Allen-Bradley ControlLogix 5561 Controller, what would you do?
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
820
Hi We were having a few power cuts and the CPU would not work. I had to reset the memory and he CPU would read from the memory card and start...
3,212
Hi, Can anyone explain the difference between rebooting a Siemens CPU 315-2 PN/DP, either by setting the switch into stop and back into run...
2,730
Got a call out to a customers site tomorrow. They have the above PLC and accompanying wiring diagrams from Nov 2013. Anyone any idea if you can...
1,440
Controller 315-2pn/dp installed on the bridge crane. Sometimes (1 time in a week or often) change its condition from RUN to Stop mode. I have...
3,607
