Siemens S7 - Function Blocks & UDT
AshleyParr
Dec 2008
Midlands, UK
184
Hi all,
im hoping that you can help me out on this problem.
I have a function block called "Valve_Control" (FB1), in this i have assigned a in/output variable as UDT0.
This works fine inside my function block but when i try to call the "Valve_Control" block i keep getting told my input into the UDT variable is invalid.
Basically i cant assign my UDT to the blocks UDT input variable,
Any ideas on how to get around this?
Ash
Sorry, i forgot to mention that im using step7 to program an S7-300 PLC
Maybe I misunderstood, but as I read it you have not declared the data you want to pass into the FB.
Today you just type UDT10 at the input to your FB?
That won´t work.
In a datablock, add a line and there you declare a new variable of type "UDT" and type in your UDT10.
This data you can now use to pass into your FB.
hi guys iam new to using siemens s7 , and I have a question with regards to the function blocks. how does one open a function block to get to the...
1,665
Hi I would like to make a array of function blocks. I'm trying to declare the array in a data block, in other platforms such as Codesys i would...
1,930
Hello PLCtakt.net I have been searching for a way to export some functions block, made with Siemens TIA Portal v12. The only way i can find is...
13,475
How can you update the tooltip text for a function block written in SCL? Currently the tooltip text shows IN:BOOL (the type of the input).
1,396
Morning all, I have created some function blocks, however while i can connect ladder logic symbols ie n/c to the inputs, the output side of the...
2,368
