Siemens S7 + TP270 + Profibus
silva.foxx
Dec 2004
North Wales; always West to England!
519
I have a 315-DP2 and a TP270 hmi linked by profibus. I have uploaded the TP270 data by ProSave via serial link that took thirty minutes to do.
To carry out a back-up of the hmi over the MPI link requires the profibus station number of the TP270.
How do I find this info?
Would this procedure be any quicker?
Please advise.
Thanks in advance.
silva.foxx :geek:
To read configuration from the controller
or
with the start of panel to enter in the system menu and to learn address in the setting.
The default profibus addresses are:-
0 - PG/PC
1 - HMI
2 - CPU
So the profibus address of your TP270 should be 1, unless you changed that in the configuration.
Paul
a little only.
Did you crank up the speed on the serial upload to the max ?
A much faster procedure is to back up to a CF card. If you want to you can copy the content of the CF card to a PC and store the image files centrally.
Hi guys, I have a trainer with a Siemens S7-315 Processor and a TP270 HMI, using an MPI adapter to connect. I have gone over every setting I can...
1,757
Hello everybody! I have a question about PLC CTI 2500 model C200. We have device with this controler but it hasn't a operating panel. I want...
1,843
Hello, A TP270 is giving us some problems when starting up. Namely, the touch function does not work for some time (like half an hour), but the...
3,330
Hi there, I have a TP270-10" Screen that I cannot download to from WinCC Flex 2008... When in transfer mode, the TP270 has "Loader B 6.0.2.23" and...
8,487
Hello to all, My coleague is trying to download project with WinCCFlex 2007. He is using MPI/DP connection and it is OK. But he keeps getting...
4,426
