Siemens Scout 4.1 can not see the licence
jugenzhu1963
Jun 2006
toronto
72
When i try to open scout 4.1 in vm ware it gives me a message " no valid licence key found application will close".In fact i have the right key installed on another computer and i set up to search the key in ALM. I can see the key in ALM. The same set up works for step7 no problem in same vm machine. The OS of the vm is win XP sp3. the host OS is win7 64.Is there anyone here had same issue before? What is the solution?
Where can i find older versions of Siemens Scout engineering softwares? like the below one? downloads...
1,153
I have a project coming up that was programmed in Step7 5.6, WinCC 2008 Flexible, and Scout 5.2. I currently have licenses for Step7 Pro and WinCC...
3,247
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
21
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
139
