Siemens SED2 VFD
Screamtruth
Jul 2005
Houston, TX
I have a Siemens SED2 VFD that runs and operates a flushing pump on our skid. The VFD is setup with a speed pot across the 1 and 2 terminals. The problem that I am constantly seeing is a drive fault indicator light that is wired into the Analog input. Also, in that same input terminal there is a pressure switch wired in. The analog input has two terminals, 10 and 11, with the pressure switch wired into 10 and the drive fault indicator light wired into 11. While running the pump for a while, then shutting it off, causes the indicator light to turn on, which somehow ties in with the SED2's motor drive circuit and prevents us from staring the motor. Does the SED2 have internal overload protection? As you can see from this post, I am not familiar with the SED2.
Any help will be helpful!
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
297
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
105
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
160
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
