Siemens test bench build
Controls Tech
Jun 2014
Inside a OR gate
54
Hello everyone, I am new to Siemens software so please excuse my ignorance, I am interested in building a Siemens test bench with a S7-1200 controller and I pretty sure that this is the software I need to program the controller, Siemens 6ES7822-0AA05-0YA5 TIA portal S7 V15.1 Basic PLC programming software. My questions are what all programming languages this software support? Is this the same as WinCC Basic (not 100%sure what this is, maybe just hmi software? ) I would like to eventually have a HMI and some small drives/servos.
WinCC Basic comes standard with Step7 Basic or Professional.
The languages are Ladder, SCL and function block diagram.
I would look into buying a 1200 starter kit
Call your local distributor.
This comes with a plc, simulator, software and cable. Great deal
Some even have an hmi in them. This depends on the starter kit you buy
https://www.google.com/search?sourc...S8Efb-Qg8#sbfbu=1&pi=siemens 1200 starter kit
Those are the trainers I was originally looking at, I was just wanting g to make sure I was understanding the software types and what they are capable of. The $999 basic kit with software, so I am correct that this software has the capability of building HMIs and programming drives? I am use to dealing with Allen Bradley Controllogix and PVP HMIs.
Yes, do this.
I have the Starter kit with the 1212 and 4" HMI, and license for the software. I think I got it through my distributor for about $500 or so (don't quote me - I don't remember exact cost!)
Hello everyone I have a Siemens S7-300 CPU 315-2DP, CP343-2P and ASI module .AC2459 I want to using it for test input output . as show in below...
18
4,286
Hi all, I'm having an issue where I was looking at the program made a change to one parameter downloaded the program changed it back to...
1,149
Hi, I search someone who wood like to test an application that I made on a S71200 PLC. Anyone who has a 1200 on his desk ? Thanks, C
42
21,327
Is there a manual or guide that details the acceptance test procedure? Customer requires System Acceptance Test on their automation cell with...
3,657
So, my problem is I have a DB of 4 strings of 254 bytes (total of 1024). I need to clear them every cycle (sorta like a buffer I guess). I tried...
1,774
