siemens tia help
stu
Aug 2005
England
785
i have a question i have a string where i see a product number , but want to be able to if less then/ equals to 1 then turn off a input ?
i have tried a comparator and basic >= but nothing worked ?
im sure this is a basic question ,i just need a little pointing in the right direction
I think You need to convert string to integer/double and then You can compare by value not by chars.
Can you describe the format of the number values in the STRING.
You can play around with STRG_VAL, the parameter FORMAT decides the format of the STRING content.
If the number format is special, then you may have to write your own conversion routine.
As JesperMP suggested - play with that function and You should be all right.
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
970
Good, Code Totalizer: IF ( Hour = 23) and ( Minute = 59) and ( Second = 59) THEN totalizerDay_previous : = totalizerDay; totalizerDay= 0; End_IF...
1,584
Hi guys I have a 1500 cpu and a bout 5 drives on a machine on profnet And I would like to see the current and monitor online I have the plc...
1,604
hi i have had a mind blank on a tia and was wondering for a easy option . i have a trigger signal that will see a mark and set a delay timer off...
3,317
Hi all. I'm modifying a system that's created in Tia Portal ver 14. I've changed the PLC program and added screens to the HMI sections. Regarding...
6,194
