Siemens TP - smartservice/email
HAROLD
Apr 2007
St Catharines
I have a tp177B and am trying to send an email on system alarm condition any help appreciated!
this is what I have tried
Smatservice installed and running
local network is connected to ISP
SMTP set properly
SMTP authentication ????
I am trying to trigger an email on the event 'high limit' of a tag value. I have set 'send email' in the tag database and use a local tag for the 'address of the recipient' This way the customer can change who the message is sent to. When the event is triggered no email is sent but the tag containing the address of the recipient is cleared (all spaces)
I need to get this right since the system runs 24/7 and subjective experimentation is not an option.
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
295
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
105
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
160
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
