Siemens TP170B Problem
jt5405
Dec 2007
Cincinnati, Ohio
Hi, I just signed up here and have searched for an answer to this, but I must say I got sidetracked several times by all the good info here.
I have a Siemens TP170B touchscreen connected to a S7 300 series that has gone dark. It is still functional, but operators can not see it. Does anyone know if the backlight is replaceable on these units. No info found at Siemens.
Thanks for replies.
Hi jt5405.
Unfortunately Siemens no longer offers replacement backlighting on their panels. The last one that had that was the OP25 and OP35.
You can send it to Siemens for repair or exchange with a new.
If you do not have the project as a backup, then you can get an image out of the panel onto a flashcard, provided that you can see the screen - if ever so slightly - maybe try to put a lamp right close to the screen. Then use the Backup/Restore aplet in Windows Control Panel.
Dear Friends, i have a problem with a Siemens TP170B. I can't transfer my project by MPI of my PC. Error Message in attach. I can't resolve the...
3,938
Greetings i need to do programming / configuration for a new Siemens TP170B what connection cable do i need ? if it is attached to Siemens...
2,420
Hi Im using Compact Logix L32E PLC and Siemens TP170B HMI using Win cc flexible.How to communicate between this two? There is no Ethernet port...
3,381
Hello, I have a service engineer on site, and he is struggling with a touch panel. The touch pointer is way off where he is pressing the touch...
4,518
Hi, we are using Siemens S700 PLCs with add-on modules and use the TP170B screen (and the replacement TP177B). A service engineer with thick...
5,385
