Siemens USB adapter
S7Guy
Nov 2003
Dayton, Ohio
1,250
I was wondering if anyone has used their Siemens USP MPI cable in conjunction with a Siemens 840D controller, specifically while using HMI Advanced to make program changes and archives. I have a Process Informatik adapter that works great with S7 PLCs, but not so well with the 840D.
I'm getting a new laptop without a PCMCIA slot (just a matter of time, I guess), so I won't be able to use my 5512 card. But that begs another question: Has anyone used the 5511/5512 card with a USB/PCMCIA adapter? I thought maybe some desktop users might have tried it.
Or, maybe this would work, although it's kind of bulky: Express Card Adapter
CP5512 is Profibus card but USB adapter 6ES7972-0CB20-0XA0 is only MPI. More over, he required power from PLC connector.
I faced with the same issue. I find out S7-LAN MPI/PPI/HMI/Profibus adapter with external DC connector.
Wath you think about that?
No, the USB adapter can work with Profibus as well.
Maybe you have nailed it with this one. But controllers (masters) typically have the required 24V in the Profibus port. Most slaves do not.
(sorry, havent ever had to connect to an 840D)
Luckily you are right!
I connected s7 300 plc to pc via siemens mpi usb adapter.I used simentic manager and view the data.It is working with simetic manager.But i can...
3,036
Anybody have failed and solved the issue of installing Siemens PC Adapter USB V2.0 driver software on XP mode running on Windows 7 using VMware...
7,015
Hello everyone, I have a new Siemens PC-adapter usb but doesn't work in accessible nodes. If i go to Set pg/pc interface pc adapter auto...
2,594
Hello everyone, A few months ago we purchased the MPI-USB adapter Siemens cable, which came with an USB to MPI module cable, the MPI module, and...
7,796
Hi folks - I'm setting up a central data historian at a customer's plant. I need to get data out of an S7-300 but the only port free on the rack...
5,069
