Siemens VS omron in software
maede
Sep 2010
Isfahan
I want to compare software's of Siemens & Omron, but i haven't worked with Omron ,Pls. help me if anybody have worked with both of them.
Thanks a lot
Have worked with CX Programmer, Step 7 & Step 5.
I prefer Siemens software apart from one thing - the online monitoring update time.
Omron is far better than Siemens for this.
I don't know what exact software you are talking about (PLC, HMI, Drive, Scada, Communications, OPC, etc...) but the concept of Totaly Integrated Automation is the key that makes Siemens software better than other software I have seen up to now.
Most of the softwares are connected to each other over and SQL database in your computer and when you make a project, after you archive it you have only one files that has it all = PLC + HMI + Drives + etc...
This is what I like about Siemens. The hardware we can argue about Siemens but the software concept is far better than other I have seen. Once I heard from a Siemens guy that software development part of the Siemens mostly the SIMATIC Manager is the most important part in automation.
On the other hand CX-One is a good software, you have a lot of hotkeys and visual side of it is not so bad, I only have problem with the commenting part and as mentioned the online debugging part is better than Siemens.
I Have gone the other way,
worked with All Omron PLC packages
Now Siemens AB etc.
Omron is easier - only due to familiarity.
I have issues with siemens when fault tracing on a new customers m/c with out the correct GSD files. Difficult to resolve at 8:00 PM at night
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
267
I want to connect a S7-315 cpu to an Omron CJ2M via Ethernet I/P and transfer mainly bit data ie. turn an Omron output on from the S7-315 or turn...
2,485
We recently created a channel on YouTube about PLC Onron Training and the others . I am very happy to Share to the community...
1,932
I am looking for addressing difference between Omron and SIEMENS. In this Ladder netwoks has W10.00 address.This is a Omron ladder. I want to know...
9,302
Hello Experts, Anyone can help me how to configure the CX-Programmer to link a communication into Siemens MP277 touch screen. Any help is...
1,934
