Siemens
I'd recommend getting a hold of a local Siemens rep to discuss things. Sometimes there are wrinkles to complicate things a little.
That said, all you need is Step 7 Basic (for the 1200). It includes WinCC Basic, for the HMI, which can also be purchased separately.
Your PLC should have Ethernet onboard, so connecting should be relatively simple. The Basic panels come in both ethernet/Profinet and serial/Profibus variants, hopefully you have a PN one.
If you don't have any of the parts yet, and this is your first time with Siemens, you may be able to get a starter kit, which is a bundle of all of them together.
Any version of TIA will work. The basic panels are included in the standard package.
I would recommend going for the newest version, and at least V14. The previous versions have been very buggy at times.
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
67
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
160
140
Hi all! Please inform me if i can make programing of the HMI SIEMENS IPC477D from TIA Portal software or not? I do not have WINCC software but...
101
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
136
