Signal Isolators for analong and digital IO
luisade101
Jan 2011
Malaysia
Hi there,
My project specifications require me to provide signal isolators for the analog and digital IO points. These include the analog input, analog output, digital input and digital output.
I managed to find that there are signal isolators for analog input and output from suppliers such as Weidmullers, Phoenix Contact and P+F.
However i can't seem to find any isolators for digital points. Based on my research there is no such isolators devices for digital points.
If you want to isolate the digital signals, the the easiest and only way is to use the normal relays. The relays will act as isolators for the digital input and output.
Anybody care to comment on this? Thanks a lot.
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
217
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
539
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
244
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
76
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
293
