Simatic Accu
gery
Jun 2002
Timisoara
17
Can someone provide some information about the ACCU of SIMATIC. I have a list with the bits from the ACCU but I can't find what they represent, a short explanation would help.
1 BR
2 CC1
3 CC0
4 OV
5 OS
6 OR
7 STA
8 RLO
9 /FC
This are taken from the SIMATIC Manual, I found an explanation for RLO, but I don't know what the other are doing. :rolleyes:
The ACCU in simatic stands for the accumilator, the figure in the ACCU will be what has been loaded into it for example :-
C DB10
L DW20
If dataword 20 of DB10 contained the decimal number 300 then the accumilator will show 300.
Paul
Accu
I belive i was not enough explicit
I would like to know what BR, CC0, CC1, OV, OS, OR, STA, RLO, /FC means,
I know that RLO comes from Result of Logical Operation, I would like to know what represent the rest of the "symbols".
BR binary result
CC 0 and 1 are condition code bits
/FC(the line above FC) First check bit
OV overflow
STA status
OS stored overflow
OR is OR command
This is in Chapter 8 of the Statement List Programming Manual
C79000-G7076-C505-02 is the order number I think. I tried finding it on Siemens site but havent yet.
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
168
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
305
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
319
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
155
