Simatic APT to S7
global1000
Sep 2004
We have a 505 PLC programmed in APT, and we want to replace it with a S7 PLC. Is there a utility or software package that will convert the APT code to the S7 code, or do we have to revert to brute force?
I'm looking for a software utility that convert the install.tag file produced by Simatic APT into an InTouch tag import file. I want to check if...
2,784
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
168
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
305
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
319
