Simatic Im- Export Event Messages Protool
Machinery
May 2004
25
Is it possible to import the symolic list from a DB into an event message in protool. I've made a DB with all errors (about 540 txt). Now i want to copy these txt and import them into Protool event messages.
I know about the problem of sequence of numbers in PLC <-> Protool, i've solved that.
Too bad you didnt ask me first.
I do it the other way around.
I create all the messages in Protool (you can use cut-and-paste), and then I export the texts (with Languages .. Export) to a .csv file.
TIP: Put the PLC address in the message text, that makes it easier to find later.
In STEP7 I export the symbol table to a .dif file.
With both the .csv file and the .dif file open at the same time, I create the symbolic adresses in the .dif file, then I copy all the message texts from the .csv file to the "comment" section of the .dif file in one go.
In the end there is a list of symbols that look like this:
Address  Symbol    Type   Symbol comment
M200.0 ALM_00_0 BOOL ALM_00_0 -Q10 24 VDC internal in panel.
M200.1 ALM_00_1 BOOL ALM_00_1 -Q11 24 VDC for interface signals.
M200.2 ALM_00_2 BOOL ALM_00_2 -K01 Emergency stop relay.
It should be possible to do it the other way around, but I have found this to be the easiest.
edit: I see that you use a DB for the messages, but that makes it a lot more difficult to edit the symbolic comments. Thats why I use Merkers for this purpose.
Hello. does anyone know how I can export my HMI project (in this case an MP277) from SIMATIC manager, so I can open it with WinCC flexible 2008...
6,547
Hello, Currently I am working on a project in which I need to export online data from a shared data block DB in Simatic Manager to excel sheet...
10,245
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
205
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
107
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
188
