Simatic NET OPC Server installed or not
naturephoenix
Jan 2015
Vienn
181
My company has been working with Siemens equipment mainly.
I've Step 7 v5.5 installed, and TIA V13 portal installed and WinCC 7.0.3 installed.
I've tried establish connection with C# and S7-300 using Siemens manuals, and all stuffs inside TIA portal and inside station configurator went well but still nuting comes to c# app.
My question is how can be sure that I have actually Simatic net opc server installed?
I can insert OPC server inside hardware configuration, I c that they are working inside station configurator, but I wanna exact sign to be 100% sure. Yes I do have this server installed or no. Inside control panel I don't c anything like that. Inside all my installation CDs there is no such a name as Simatic NET OPC server.
Inside control panel I see WinCC/OPC
If Simatic Net is not listed in your Program in Windows Control Panel, then it is not installed. Another way to check is clicking "Installed Software" inside Step 7 5.5 and V13.
Step 7 V5.5 - Go to Help -> About ... and click the Installed Software button
TIA Portal V13 - Help -> Installed Software
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,915
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,423
I have a client that has a PC (win7) that runs the Simatic Net OPC server. To this OPC server there are several S7-300 CPUs connected from...
3,137
Hi all! Is there any way to configure opc server on pc side, to communicate with s7-1200, only by entering ip's and etc in opc server software...
3,461
short question. I have a costumer that has installed a simatic.net OPC server. I am making a tag list for him to import. I thought it would be...
1,589
