Simatic s5-010 plc
Clarence
Jan 2010
Belwood
Hi. We have a Siemens Simatic s5-010 plc on a lathe which was not used for some time. The battery may have been dead long enough to lose something on the eprom. Can anyone tell us how to get the program out of or into this plc. It is a 1981 (old)unit but we do have the program documentation. Thanks, Clarence.
Never heard of that type of Siemens S5. Are you sure it isn't an S5-100U?
EPROM doen't need a battery to retain its programming. The battery is only used to retain the programming in the RAM memory.
If you have the program documentation on paper, then I suggest you start typing in the program using the STEP 5 programming software or an alternative (search the site for e.g. IBH Softecs S5 for Windows). If you have it on disk, then I think you have the source file and can simply transfer the soft to the PLC using the same abovementioned programming software.
Kind regards,
Hi. Thanks for your responses. Yes it is a S5-010. If you check Siemens online it is lited as well. The "Failure output - 0C.4" is flashing on and off, and the digital readout is at 5.5. I'm not sure what this indicates. Thanks, Clarence.
:scratch: I have an old Hermle CNC machine with a Simatic S5-010 PLC . I have been looking for manuals for this PLC on the homepage Siemens, but...
1,653
Anyone have link for EKB of Simatic S7 v5.5? Please help
5,307
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
177
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
313
