simatic s5-100u cpu 102
rezayat
Apr 2004
Iran - Tehran
dear sir
We have one plc simatic s5-10u with cpu 102 and with 6es5-375-ILR15 memory module first of all . we need schematic diagram for this type PLC and also we need data information of this memory module .
the symptom that we have in the system is this plc when we program load it does not go to run mode . would you please inform us how we can solve this problem . we will appritiate your eforts befor hand .
your sincerly
Rezayat
Your mememory module should be 6es5-375-1LA15, an 8 kbyte EPROM module.
You need a Siemens ProGrammer to burn it
Are you sure that the program is correct? If you use datablocks make sure that you download them to end so on. Perhaps if you could give a more detailed information we would be able to help you.
Rudi
Dear all, I am facing problem in my SIMATIC S5-100U PLC as it went to STOP mode it is not going back to RUN mode even i reset it...
8,111
We have an old system controlled by a siemens plc s5 with order no. 6es5 102-8ma02 we want use for this system operating panel siemens op25 but so...
2,881
What is the memory size for Siemens Simatic s5-100u-cpu 103? part no: 6es5103-8ma03 Is the memory for logic seperate from memory for data? What...
5,194
Dear sir We have a diecast machine with system controll of simatic s5 100u the prolem that we have is: it won't go to automatic mode so we think...
8,281
K
siemen's simatic s5/100u does not have retaintive off-delay timer. how to achieve that functionality(simpler than looping with counter)?
1,838
