Simatic S5 Comunication problem
Chandrashekar
Nov 2005
riyadh
42
Iam new in simenes s5 program,i need some help from you people
I INSTALL THE S5 V7.23 SOFTWARE ON MY LAPTOP COMPAQ Presario.but there is no serial port in this laptoP, There is 2 USB Ports are there,i have interface cable S5 PLC to PC 6ES5 734-1BD20, how i can use this cable to download the plc program from plc S5-90U to my PC
Hello,
I think you need an USB to RS232 converter. Do a search on this site this question has already has been asked nummeros times.
Rudi
S5 comunication problem
I Purchased One Mini Usb Dock And Connected With My Laptop To Plc S5 95u Plc.when I Try To Conect Online Diplay Is Showing:plc In Cycle-stack Output Stopped
Please Help Me To Fix The Problem
The PLC interface uses a 20mA current loop, so you need a converter from RS232 to 20mA current loop as well.
This has been dealt with in several other threads.
Kind regards,
Here gomes general insruction for Simatic S5-world
TTY (Current Loop) connections and principles.
Hello. I'm trying to comunicate to Siemens SIMATIC ET 200S IM 151-8 PN F-CPU using CitectNexa 6.1 via Ethernet. I don't know wich Citect driver...
1,723
Hello Everybody! I am looking for information about cable comunication Simatic Panel Pc 670 with S7-300. Somebody have idea for make this cable...
2,478
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
213
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
108
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
188
