Simatic S5 -Seven Segment Display
sam_1977
Nov 2008
Egypt
Dear Friends,
simply iam taking my very early steps into the SIEMNS S5 and iam surprised by the first task i need to figure out
i have in my S5 Program (specifically, in DB)a value that is sent from PLC to "process visualizing software"
anyway, my target to display this value in DW of DB on 7 segment display ,could anyone please help me to configure how is that?
thank you in advance,
sam
Depends on the type of display?
Can be as simple as an output byte in hex or binary code thru to RS232, 20mA, RS485 etc.
Have a look at london electronics.
I have ever used 4-digits 7-segmet directly to digital output for integer value (2 bytes) . Value from DB or F is converted into BCD then I move it directly to digital output just using Load/L and Transfer/T function.
I connect each 4 bit of D/O to each digit number of 7-segment. Remeber to make 0-9 number in 7-seg you need 4 bits
I am new to this forum and would need your help. I am looking for the Modbus FBs for the S5 95U for communication with the CP521. These FBs...
55
Hello Everyone Im Trying to Study a PLC programm of a Pet Blower machine, it is programmed in Simatic Manager Step 7 in STL/AWL Lenguage in a part...
110
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
320
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
127
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
211
