Simatic S7-300 Interface Module
Guest
Guest
G
Dear All,
I used Simaticn s7-300 CPU 314 (6ES7 314-1AF10-0AB0)
Also I brough device SIMATIC S7-300. INTERFACE MODULE(6ES7 365-0Ba01-0AA0)
What is this function ??
does it use to connect different CPU ?
OR does it use to connect different I/O Module with different rails?
Moreover I have bought many I/O Devices so they cannot linked together in one rail(6ES7 390-1AF30-0AA0) . How can config and connect the i/O devices in other rails to the main CPU?
THX
April
The S7 300 mounting rails have a maximum of 11 slots. Since slots 1 -3 are reserved for the PSU and the CPU, this means you can mount up to a maximum of 8 I/O modules on the rail. If you need more I/O than this, then you must add more mounting rails (up to a maximum of four in all). To couple these together you need can use either the IM360/IM361 combination if you need more than one extension rack, or if you only need one extension rack, the cheaper IM365s.
You don't say how many I/O modules you've got but if you need more than one extension rack then you must use the IM360/IM361 combination.
There are a couple of restrictions with the IM365 - the power for the extension rack comes from the CPU rack, so make sure the PSU is properly sized, there is no connection between the K-Buss of the extension rack and that in the CPU rack, so you cannot use a CP or FM module in the extension rack.
Hope this helps
Roy
365 function
Hi April,
The 365 card is used to connect more than 8 cards to an S7-300. The first 8 are connected directly, but for more you need an interface 365.
You must insert it in the STEP7 - HWConfig software, in the slot number 3 of the main rack and insert another rack as secondary. Then you can plug more cards on this new rack.
Hope this helps
PLCs are our friends ¿aren´t they?
hi, i was called in to help one of our customers with their PLC. it is a siemens which i'm not very familiar with. i typically work with GE...
6,117
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
177
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
313
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
132
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
770
