Simit + plcsim
Farnesi
Jun 2009
Austria
46
Hello all! :geek:
I have installed on the same computer (notebook actually)
Step 7 V5.5 + SP2 (K5.5.2.0)
SIMIT VERSION 7.0.301.263 SP3
S7-PLCSIM Version V5.4 + SP5 + Upd2 / Revision No.: K5.4.5.2
My S7 project has two PLCs and I have two instances of the PLCSIM running with each one.
On the SIMIT project I have two Gateways, both created with the PLCSIM Gateway option. Each gateway for each PLC.
The problem is: the SIMIT is able to write on the PLC INPUTs, but when the PLC OUTPUTs changes on the SIMIT there is nothing coming. It is like the communication between SIMIT and PLCSIM only works one way. PLCSIM is not able to write on the SIMIT I/O table.
This project was ran before on the SIMBA (worked fine). But I dont have any hardware to run this and I have decided to try the PLCSIM together with SIMIT..
Hi, I was wondering if someone knows wether it's possible to acces Data Blocks from te PLC program with the SIMIT read/write DataBlock...
889
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
563
Daft question coming up...When I want to modify a value, what's the best/correct way to do this? At the moment, I am entering the value (e.g...
457
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
379
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
587
