SIMOCODE once again
panthripu
Mar 2004
228
Dears
Once again need your support. I am starting on a simocode.After factory reset, I am trying to make some changes or reconfiguring the simocode but after this I am not able to download the new configuration to device with Simocode ES software.
It says " parameter change not possible currently" Motor may be running.
This simocode is on my workshop not connected to motor. After google , I found some remedies like , Motor ON feedback in protection control. I made it permanent 0 . Even the remote mode is disabled. But no use.
Can someone explain the possibility.🍑
simocode
Hi
Thanks for your response.
There is no profibus connection. I am checking this simocode on my test table.Even when i go online , i dont find any place to disable Profibus communication.
OK,
Tomorrow i am back in the office.
There i have some Simocodes, i can do some tests.
I assume you have a Simocode Pro, and not a Simocode-DP, since you use simocode ES for programming.
Siocode
hi
Once once again google helped me.:cool: Factory reset and problem solved.I configured the simplest configuration for single direction and reversing starter but simocode shows general fault. Diagnostics shows configuration error. I dont know where is the mistake.
Check that in ES you have:
- Correct (firmware)version for simocode pro
- Correct size for current module
- If you have additional I/O-modules, correct types for these modules
Good afternoon all. I would like to be able to simulate sending and receiving specific bits between my Simocode pro V EIP module and the...
1,374
Hi, I'm looking for the eds file for a simocode module "BASIC UNIT SIMOCODE PRO V MR". So far, I can only find the eds file for the pro V EIP...
1,742
:banghead::banghead: Dear all, we have a SIMOCODE that is used to turn on/off some important pumps in the factory. Communication is via...
2,270
Hi guys, We have a conveyor at work that had a flight break off and did damage to the conveyor. We use Drag Conveyors......I was asked if a...
1,649
Hi I am looking for some help with Simocode Pro V. I have an issue where there was a power fail on site and now two Simocodes are not...
4,373
