Simple data selection and reports
Jun 2015
Davenport, IA
I've got what I think should be something simple that i'm trying to accomplish but isn't turning out to be so simple.
I have a "recipe" for a part that contains 11 columns of data in a .csv file that was created using a Maple Systems HMI5121XL. Part Name / MagTime / DemagTime / OutputType / etc......
I have customers that are fine with the ability to run 50 parts and then I have customers that want to store 1,000 part combinations. Seems pretty simple on a Maple, but when I try to do this in a AB PanelView Plus 7 it doesn't seem so easy anymore.
If I use the active X recipe control it creates a file for every part and then limits me to 255 files. If I use recipe plus then I can't edit the files very easily without view studio.
There's got to be an easier way to accomplish simple recipes/database selection and control that i'm not seeing. The ultimate goal is to get the database out of the plc so it's easier to backup and edit and give me the flexibility to run hundreds of part setups. FYI, we're running with a micrologix 1400.
I've used indusoft in the past and I could almost do whatever I wanted with that software and i'm starting to think I should give them a look for this company instead of allen bradley.
Anyone have any better ways or ideas to have a parts database that I can select from on a HMI to run with a micrologix and be able to do some basic reports with?
I need to have an array tag that contains string data from a csv file. The csv file needs to be imported once per day. Is there any simple way to...
1,814
I'm trying to figure out a cheap/simple way of saving some recipe and configuration data out of a Compactlogix PLC (L33ER) and Panelview Plus 6...
2,071
Hi I've got a Micrologix 1400 and I'm using RSLogix 500 micro starter. Basically, my application required about 200-300 integer values that will...
7,753
I like to collect some data from a Siemens S7-315. The PLC will send data after each machine cycle. The data should be stored on a computer in a...
3,227
I need a device that will monitor a single digital input (auxiliary contact of motor starter). The "device" must store the start time and date...
1,668
