Simple Ladder Problem
afm
Aug 2023
Tennessee
88
I have a program that does a 7 second "scan" sensor calibration routine whenever a setting (setting is called assistance level or "AL" and ranges from 5-10) is adjusted on the HMI. Currently, a scan occurs every time the AL setpoint setting is changed (the rescan is triggered when the HMI buttons are pressed to adjust the AL). I want to reduce the frequency of the scans that occur, and I only need it to scan when the AL is changed to 5 OR when the AL is change to 6-10 (rescan calibration is not needed as the sensor is not affected significantly between AL settings 6-10). For example. If I am at AL 5 and change to AL 10, I want a scan to occur, but if I switch from 10 to 6, I do not need to rescan. But if I go from 6 to AL 5, I want to rescan. I attached my current code. for the current code. For context, while the MinTimer is timing, I run the rescan, so I need some help with updating the "AssistLevelChange" variable to only trigger with the above scenario.
Thanks for this. The AL setpoint actually ranges from 0-10, but for the context of the sensor scans, I am only looking at when AL is between 5-10 range. This was my approach. I could have used an "if AL GE 6-10" function block to keep it concise. I like your process to identify switching between the rescan thresholds using the memory bits, thank you.
When the AL is changed the MinTimer restarts which triggers my scan logic :
It would be awesome if someone could help me out with this problem. We can only use basic XIC XIO OTE OTL and OTU instructions. I'm not sure on...
33
9,185
Hello to all, I have one problem and hope you'll be able to help. I want to write simple ladder diagram program. I want to programm the...
3,364
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
180
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
369
I need help answering a problem regarding the design a ladder diagram for a security light control. The question states when a sensor is...
2,087
