simple math with DL06
qlingtime
May 2005
Hi everyone,
I am having a little problem verifying some math results being done in DL06. Doing simple math in DL06 suppose to be relatively easy and straight forward but I must be doing something wrong that my results are not coming out correctly.
here's part of my program:
LD V2020 -- V2020 contains integer 50
DIVR R4 -- dividing accumulator by real # 4.0
OUTD V2022 -- save result (should be 12.5) to V2022
LDR R320000 -- load real # 320,000 into accumulator
DIVR V2022 -- divide accumulator by what's in V2022
OUTD V2024 -- store result into V2024
but my "DATA VIEW" shows V2022 = 12 and V2024 is some garbage #. I tried looking at it w/ BCD, decimal, real... none of the options would give me the correct number.
Can anyone see what I am doing wrong? Any help would be greatly appreciated.
Thnx,
--tong
The problem is your first instruction. Actually it's ok but after it executes the accumulator holds the BCD number 50. Then you attempt to divide by a REAL number. This is apples and oranges. It doesn't work.
Unfortunately there's not a BCD to REAL command. It must be done in 2 steps. So, after your first instruction place these:
BIN - converts the BCD number in the accumulator to a binary number
BTOR - converts a binary number to its REAL representation
Your other instructions should then work fine. View the final result as a REAL number
Well...
We really don't know that it contains a BCD number. All Qlingtime said was "V2020 contains integer 50". It could be a Decimal integer. In which case all he needs is a BTOR.
If it is indeed a BCD number (Ie. it reads correctly as an integer when viewed with BCD/Hex) then Bernie is absolutely correct.
In any case it is apples and oranges as Bernie has suggested. The number formats must match. Otherwise you get garbage out.
I made a bad assumption when I thought if i divide by a real #, the result would automatically become real.
Thanks very much, I'll try that out this weekend.
thanks very much guys, I only had to do a BTOR and all my munbers came out correctly.
You guys are the greatest :)
hey Guys, I want to take my five counters, add them and multiple by 10, I got it to work, but WAY to many lines. Any suggestions...
1,791
Guys I'm sure this is simple, its just not for me. if an i/p is calibrated for 10-50ma input equals 6-50psi out. what is the out at 25ma? What...
2,157
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
173
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
260
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
320
