simple micrologix 1200 question
joelchickey
Jun 2015
canada
I have no offline files, and i need to copy a program from a working micrologix 1200 to a new micrologix 1200. We typically don't turn this machine off...so my question.. is can i do an upload of this micrologix 1200 program without leaving run mode? or will i have to leave run mode in order to make the back-up i need?
thanks.
Joel
Yes.
BTW, you will not get any documentation. As that is only stored in the offline file.
For some reason, I cannot get even the most simple integer to integer function to work, e.g., (MOV N18:24 to N31:2). I have also tried MULT...
2,537
Hi I've got a Micrologix 1400 and I'm using RSLogix 500 micro starter. Basically, my application required about 200-300 integer values that will...
7,753
I am a newbee who could sure use some help... I am using RSLogix 500 and a Micrologix 1400. Can someone help me with some simple ladder logic...
3,662
Hi, im interested in using the Micrologix 1100 with encoder and and AC drive on slow moving machine for cut to length function. I have not done...
2,236
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
165
