Simple Modbus TCP logger
ISL_MAN
Aug 2005
rOTHERHAM
20
I'm trying to get this software to log data from a twido TWDLMDA20DRT which I've ethernet enabled using the twidoport 499TWD01100 ethernet module. I've had this same software working find with a momentum PLC but can't get it to function with this setup. The error I recive is 1 Query sent to slave and no responce within poll interval. Has any one used this software before. I can get a demo of kepservers modbus TCP opc server to talk ok but this is three times the price of modicoms Simple TCP logger. http://eclipse.modicon.com/ look under Networking support to see the software I'm trying to get working.
As usual soon as I post on here I find the solution myself by accident I may add. I've had to use hyperterminal to reconfigure the twidoport unit's gateway configuration. I've changed the Slave address Source from UNIT_ID to FIXED with a slave address of 1 which happens to by my PLC modbus address. I then had to put 1 in the bridge option on the Simple Modbus TCP logger program and it started working.
Hi guys, I'm looking for a simple and cheap solution to create modbus network, read devices and log data on PC. I have 5 modbus compatible...
4,270
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
165
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
197
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
275
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
333
