Simple resistor question
monkeyhead
Sep 2004
I'm right here
656
Are 2 24Kohm 1 watt resistors in parallel equivelant to a singe 12Kohm 2 watt resistor in regards to their power rating?
I know resistance-wise they are equal, but I have no idea about the power rating.
Plenty of free air around the component they'll be mounted in parallel with. It's a cheap buzzer that i'm using an AB 1746-OA16 triac output card to turn on and off. I thought it was a relay output card and once I installed the buzzer, it gets a constant hum when the output is off.
Thanks.
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
170
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
197
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
277
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
334
I have a program that does a 7 second "scan" sensor calibration routine whenever a setting (setting is called assistance level or "AL" and ranges...
226
