Simulate PLC's
Sefirod
Feb 2009
Barcelona
I'm new in the world of PLCs, and right now I don't have any real PLC to play with, so I am interested in simulation SW.
Actually I am using PCVue for the control and adquisition of the data. What I am really looking for is a software able to:
- Simulate a Siemes S7-300
- Execute code programmed with SCL language
- Communicate/connect with a SCADA (PCVue in my case) for data adquisition
Is there any SW that matches those requirements?
I've heard of S7-PLCSIM and WinPLC 7, but I don't know about their real capabilites...
Thanks for your help!
Thanks Doodie, the logixpro looks great (and cheap!).
Unfortunately, I think it doesn't allow you to connect with any SCADA, neither import any SCL code to the PLC.
I'm starting to think that all the PLC simulation software are just for that, for simulating a PLC. They let you play with them as a PLC, even try your code, but none of the simulation SW I found had connection capabilites with a SCADA for controlling and/or data acquisition.
Thanx for your help, anyway!
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
566
Hi all, Im new to Allen Bradley software, so i was given a existing studio 5000 plc program. i already know how to use emulator and rslinx but as...
1,436
I want to run a simulation of a program uploaded from a rockwell PLC, but I can't configure the CPU on the emulate to match the actual CPU.
2,306
Hi. I have a legacy project with an SLC500 PLC (SLC5/04 CPU), and we want to connect a data logging system to it. Management want to make a test...
2,725
I have a real PLC siemens ET200SP and I have created a modbus program in this to read data from a modbus slave using Modbus TCP how can I...
3,184
