Sinamics G110 auto start
Plavyuk
Oct 2011
Dublin
Hi guys. I replace the faulty inverter on the industrial oven. It was wired for automatic start up , jumper between pins 6 and 3. I did the same but after power down, inverter is not running. Any ideas? I checked the parameters but cant find anything.
Hi
I expect the drive comms preset to use Profibus controls
If using hard wired, look at the I/O parameters for digital inputs section I think it needs to be set to 12 from memory. I usually save the drive config to the op panel..maybe you could check and see if someone else did that before.
We've got to mount a serial comunication between several Sinamics G110 inverters with a RS485-US protocol and I'd like to know if I can give them...
2,054
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
109
Hello, I use a Siemens Sinamics G120C inverter in combination with a S7-1200 cpu. I use the Main Setpoint with the Providrive option and send...
763
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
966
hi every one is t possible to power the (6SL3244-0BB12-1FA0) CU240E-2 PN unit with an external power supply 24vdc without the need of the power...
569
