Slc 100 Not holding program
Daniel Peck
May 2010
NC
I know its old but we are using them in a High school for basic traning. I have one that will not hold a program in memory after unplugging the unit it has nothing left in memeory. What do I need to check out for the problem.
Daniel Peck:unsure:
There's a lithium battery inside that is probably toast.
Also, there's an EEPROM option (p/n 1745-M1) that will allow it to keep the program even with a failed battery.
It has a eeprom Which I down loaded to and it runs, when unplugged and plugged back in it is lost.... I think the eeprom is bad.. Anyone else had this problem......
For a SLC-150, you must add logic in your program in order to ensure that it is loaded when you power up the unit. Rung 1 should be a an unconditional coil with address 864. According to the manual, the SLC-100 should do this automatically unless the EEPROM has an access code.
I have 3 of these in the shop. and this one has the only problem. I am going to switch out the EEprom tonight and see if that works... Might be a bad EEprom.
Hi everyone, I have a broken SLC 100 expansion module that I need to replace my question is do I have to do any programming to achieve this? from...
1,592
More of a "Is this normal" question. I was troubleshooting why I couldn't ping an SLC from my desk. I have a Spider 5TX between my 5/05 and a...
1,745
Hi there, as the title suggest I was hoping that someone could help me out a little bit. I am currently updating an pallet trolley system from...
1,348
Hello Friends I have gotten a UDS1100 to connect a 5/04 PLC to Ethernet through serial port. I have set the IP address in the UDS1100, but I can...
2,187
Hello Friends I need to share some bits and integers between SLC 5/04 and a ML1100. I am thinking in Lantronix UDS1100 connected to a switch...
2,139
