Slc 150 Scan Instruction 869
bap
Jan 2008
New Jersey
i AM CONVERTING A SLC 150 PROGRAM TO SLC500 BUT CAME ACROSS
AN INPUT LABLED SCAN WITH AN ADDRESS OF 869 I CAN'T FIND IT IN THE USER MANUAL SPECIAL INSTRUCTIONS STOP AT 868 IT LOOKS LIKE SOME SORT OF ONE SHOT HAS ANYONE HEARD OR THIS...THANKS I'M NEW TO THIS FORUM.BAP
Fast counters
Hello bab and welcome to the fourm.
Address 869 thru 873 are use as fine time base counter. They count the scan rate of the program.
For the SLC 100 the rates are:
869 = Scan rate
870 = 10
871 = 20
872 = 40
873 = 80
For the SLC 150 the rates are:
869 = Scan rate
870 = 10
871 = 20
872 = 50
873 = 100
These are usually place on line with counters.
The special registers were used for 'high speed timing', since the SLC 100/150 have a default of 0.1 second resolution. What they did was to provide dedicated bits that toggle at a fast rate, and then you would use a counter to essentially count the time, using these pulses. I also translated one recently, and the easy way to do it is to use a timer with a 0.01 base, and move on.
Now, if the programmer really intended to use the 869/870... for blinking a lite or other function, of course you could generate an equivalent bit with a time, or, perhaps use the S:4 register to save some work..(that's what I did).
How can I get a schematic for it? I am unable to communicate to it using PCIS with a 486 PC and suspect the SLC150 to be faulty (found in a junk...
3,136
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,163
Hi, I have an old SLC 150 processor that is throwing up a CPU Fault light. I have an EEprom program chip for it, but I can't get it to load up...
2,353
We have 3 SLC-150s that we are using, we would like to create a print for them and diagram the program so when we get approval we can replace them...
2,677
Hello, I am completely new to PLC's (and forums) and have been tasked to repair/upgrade a conveyor system at my college. It currently has an Allen...
2,705
