slc 150 single output up/down??
jBetts
Apr 2004
Hey all,
I know they're dinosaurs but we had one lying around and I guess we're putting it to use again. I'm getting most of the programming, but nowhere in the manual can I find a 'single output up' or equivalent instruction.
Does anyone know if or how to do this in a SLC-150? Much appreciated!
Josh
Oh, sorry, let me clear that up.
Single output up (called SOTU I think by IDEC), is a flag that turns on only when the bit is activated.
Say you had a device you wanted to reset when the conditions were met, perhaps when an input turns 'off', but the input isn't always going to be on. Then this will only be true for the single program scan where the input actually is turned off.
Hope that helps, I can go in-depth on my project need be.
Thanks,
Josh
I think you are looking for a "one-shot" instruction.
As you said, this is a very old processor. It is missing a lot of functionality that we all take for granted in the newer units. I did a very quick look through my documentation for a SLC-150 and I didn't see a one-shot anywhere. I think you'll have to roll your own here.
I seem to recall that you can't branch outputs in the SLC-150, so it should take you two rungs, something like:
Input On One-Shot
On Last Time
Input On
On Last Time
Good luck,
Marc
PS: Steve typed faster than I did. In my example, I inverted the state of the "Input" (or "event") to match your description.
And this works like a one-shot, eh? Excellent, thank you all for replying.
I have to go finish dusting off the SLC, then I'll let you know if I hit any snags.
edit: So does the program scan in which the input turns off, the 'Last Time' would be on for 1 scan, so that triggers the 1 shot? Am I reading that right?
Regards,
Josh
How can I get a schematic for it? I am unable to communicate to it using PCIS with a 486 PC and suspect the SLC150 to be faulty (found in a junk...
3,115
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,155
Hi, I have an old SLC 150 processor that is throwing up a CPU Fault light. I have an EEprom program chip for it, but I can't get it to load up...
2,340
We have 3 SLC-150s that we are using, we would like to create a print for them and diagram the program so when we get approval we can replace them...
2,655
Hello, I am completely new to PLC's (and forums) and have been tasked to repair/upgrade a conveyor system at my college. It currently has an Allen...
2,691
