SLC 20A communication
gmultani52
Oct 2003
75
Hi
I want to conect slc 500, 20A to laptop. i have 1747-pic with 25 pin female socket, But my problem is that laptop having 9 pin serial port. how to connect my laptop. please advice.I also have cable C-10 which communicate to hht dirrecty. thanks
On the mechanical side, you most likely need to use a parallel-serial adapter(25pin-9pin). The adapter will plug into your computer, and the C-10 will plug into the slc 500. Do you already know how to set up the RSLinx?
Hi tom,
cable i will get from radio shack.
now how to communicate though rs linx. there maybe problem of password also becouse slc i purchaged from e-bay. so how to clear it. Thanks
As an additional note, a lot of people have problems getting the PIC drivers to work with Windows2000 or XP. I have been able to get 2000 to work, but have never tried XP. I've read that the older pic boxes are not supported.
In RSLinx, you will need to open the "configure drivers" box. In the list of running drivers, if you have anything running that uses the com port, you will have to stop (or sometimes delete) that driver.
In the drop down menu next to the add new slot, select the 1747-PIC/AIC+ driver, and add it. You will probably need to select the "reserve this com port for exclusive use" box. At this point, if using 2000, I've always had to shutdown and restart my computer. After that, you should be able to connect to the slc.
I wana communicate with AB PLC 1747 L20A, I want to now that how can it communicate with that processor I have RS 232 in my Laptop and also what...
1,617
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
103
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
