Slc 5/03 and microview 2707-mvp232
nmk
Dec 2002
38
The microview is made for the micrologix plcs, is it possible to use it with scl 5/03 serial port? and if yes, what is the cable pinout?
thanks
The Microview Operator Interface was not made to work with SLC 5/03 PLCs, or any other except for the MicroLogix. To make it work would require some engineering and a custom-made cable. Even then there could be problems. Many SLC 5/03 will not have the 24 volt DC power available. The RS-232 port on the SLC 5/03 has a different pin configuration than the MicroLogix.
Hello I have a problem with configuration the Flex I/O profibus module. I have a PLC SLC 505, Profibus scaner on PLC Rack [SST-PFB-SLC] -...
58
Howdy everyone, My company has a few machines running on SLC500 based PLC, and everytime it makes a part we count up on the counter which gets...
341
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
31
743
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
117
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
133
