SLC 5/04 to PVP700
Oceansoul
Apr 2010
England
307
Hi. I am trying to set up a new HMI to an existing SLC 5/04 using DF-1 comms. The HMI i have is a PVP700 2711P-B7C4D1.
I have added the path to the SLC into the RSLinx Enterprise tree and matched the comm port settings of the SLC but i am still having no success. Attached are the RSLogix 500 and FTVStudio config screens. I am using a 1747-CP3 cable.
EDIT: I cant get onto the major image hosting sites at work, so the images are located here, which i cant seem to embeed.
http://q75i.imgup.net/PVP700Conf7a69.png
http://d60i.imgup.net/SLCConfig41dd.png
Add a null-modem adapter to your 1747-CP3, or use a straight-through serial cable.
The PanelView Plus serial port is a "DCE" type, which has the Tx and Rx pins opposite the "DTE" types on your PC and on A-B controllers.
Cheers guys. I have it working now. I happened to have a m-f mini null modem adaptor laying around I can use for now. Going to have to make up a cable at some point for the install though. Is it just the tx and RX pins that need connecting or all 9?
SLC-5/04 to PanelView Plus DF1 Full Duplex protocol over RS-232 needs just Tx, Rx, and Ground, so it's Pin 2 to Pin 2, Pin 3 to Pin 3, and Pin 5 to Pin 5.
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
313
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
110
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
122
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
129
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
160
