Slc 5/04
kbradray
Jan 2006
Columbia
175
OK guys I have been out of the game for several years, but I am sure it will come back to me. I have a 5/04 CPU that is flakey. What is everyone using to connect to the mini round connector. In the past it used to be a PM02 cable, but I am seeking the best solution today. (USB to 5/04 round programming port)
As always you help is greatly appreciated.
Ken
Hi Ken,
The PM02 is for a MicroLogix PLC, the round mini din on a 5/04 is DH+ and you will need a 1784-U2DHP cable if you are looking for USB to that port, we sell a aftermarket version that works great and is 1/3 of the cost
If you are looking for the cheapest way just use a USB CP3 cable that will connect to the DB9 port on the 5/04
Mark
Thank you for the correction
I told you it had been a long time. Thank you for the correction. Which cable brand do you sell. Meanwhile I will take a quick look on your website.
Ken
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
88
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
103
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
80
