Slc 5/04
Keldog
Sep 2005
Nova Scotia
160
I have a SLC processor that keeps faulting on me, i was wondering if there was a bit in the processor that can be used to monitor when the processor faults.
check to make sure that all of the input cards are installed in the rack
other than that the best way i have found to find problems is to cut some jumps out until i find the sub that is giving a problem.
What kind of fault??
When the processor faults, it stops communicating, so monitoring the bit really doesn't help much.
Instead of watching for a bit to tell you when the processor is faulted, you need to fix the problem.
I would also try toi find out what type of fault it is once you know that then it'll be easier to troubleshoot in the slc instruction set most faults are recorded as a status bit also which SLC?
Is there a device plugged into the DF1 port on the CPU, such as modem or a serial DF1 PV ? That little ferrite core that is shipped with the CPUs has/had a purpose.
Ian
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
107
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
118
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
121
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
108
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
93
