SLC 5/05 ethernet connection with fault
Mr. Ro Bot
Oct 2019
at home
23
Hello all! I have some machines that run an SLC 5/03 and occasionally a fault is generated.
Recent Example: A power supply wasn't screwed in all the way and it faulted the PLC. I'm 500 miles away so I can't be on site easily to reset the fault.
I'm wondering if I swap this out with an SLC 5/05 would that solve the issue? Can you connect to the PLC remotely to download a program and/or reset a major fault. Or would the major error/fault stop my ability to remotely connect to the PLC?
That is an option, you would also have to add some sort of remote access device to be able to get to it. A major fault won't stop you ability to remotely connect. Of course, if it is caused by hardware, you would have to have someone there to resolve it.
In your example, if someone would have properly reattached the power supply, then toggled the key switch PGM > RUN > PGM > RUN, it probably would have cleared the fault. As long as the fault condition is corrected, the key switch can clear the fault.
If the 5/05 is too costly, there are devices that can put a serial connection on an ethernet network.
I have an old slc 5/05 I am trying to setup on ethernet and I cannot see it in links... I have the following equipment: PC = windows XP Slc -...
1,941
Hi. I need to make a Ethernet-Ethernet connection between two Rockwell SLC500 5/05 for data transfer. Can anyone send me manuals, links and...
3,988
Hi , I'm Trying to connect SLC 5/05 C series & PVP 1500 with Ethernet Cable But The connection is not established SLC/IP : 169.254.115.59...
3,510
Dear Friends; I want communicate SLC 5/05 with my PC (W2K installed) through Ethernet cable. Presently I have been working through RS 232 cable...
2,589
Hello, I've recently converted 3 existing processes from an OPTO22 control system to a SLC 5/05. Now that everything is in operation, my...
3,803
