SLC 5/05 Ethernet to DH-485 Setup
odsquad64
Nov 2013
SC
So I'm new to PLCs and I've been tinkering with some spare parts we've got laying around.
I've got a DH-485 network set up with an SLC 5/02, 5/04, and a 5/05 set as nodes 1, 2, and 3 respectively. The 5/02 connects through a 1747-AIC and the others connect through two 1761-NET-AIC's. All that works perfectly and when I connect to it through the 1761-NET-AIC I can see them all fine.
I've got the 5/05 connected with ethernet to our network and I can see it and program it and whatnot.
Looking at it in RSLinx, the first time I expanded "Channel 0, DH-485" It showed nodes 01, 02, and 03, but they were all the 5/05. I went into the Channel Configuration settings for the 5/05 and I figured out that if I set the Channel 0, DH-485 Passthru Link ID to 2, then I could see the 5/04 and the 5/05 when I expand "Channel 0, DH-485" in RSLinx, but I still can't see the 5/02.
I tried fiddling with the Channel 0 and Channel 1 Passthru Link IDs, but nothing I did would let me see the 5/02. I tried adding a Routing Table with the computer I'm using's IP address set to various stations, but that doesn't seem to help either. Also, I made sure S:34/0 = 0 and S:34/5 = 0.
Is there anything I'm missing? I'm thinking there's something about the node settings that's keeping me from seeing that 5/02, but I'm not really sure. Any help would be greatly appreciated.
Working on an incremental upgrade of existing SLC 500's and Panelview 550's over DH-485, to ComapctLogix and PVP 7's over ethernet. My test setup...
2,504
Currently we have a SLC 5/03 processor talking to a Panelview 550 via a 1747-AIC DH485 Link Coupler. What we want to do is add the ability...
3,677
Here's my situation: Multiple SLC-5/03 that share data via messaging over DH-485. The client wants to get rid of the DH-485 network and go to...
4,521
Hi Folks I was wondering whether you can use point io in order to communicate with an SLC 5/03 processor. I am thinking of using a 1734-AENT...
3,349
Hi guys, I have a SLC 5/03 with one free DH-485 port. I need to transmit some data from the PLC to PC for monitoring. There is only Ethernet/IP...
3,155
