Slc 5/05 Html
Jezz
Dec 2002
Kendal
399
Hi while browsing through the help file in RSLogix 500 I found a mention of user provided HTML pages has anyone used this feature ,can it be used to display live data on a web page if not what can it be used for ?????
[rainbow]:confused: Jezz :confused:[/rainbow]
I have used web page feature in the SLC 5/05. It does not serve live data it only takes a snap shot. You can make it to refresh say every second but then you will see the whole screen refresh. I mean it
does not look good.
This feature has only limited functionality don't expect too much.
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
93
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
103
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
80
