SLC 5/05 Min / Max...
bluenoser337
Apr 2003
Nova Scotia
391
I know there is no instruction to return the "min" or "max" value from a file, but somebody must have created some cool code to do this...perhaps using indexed addressing...pointers? Looking to find the min and max of 56 float values without 56,000 lines of code. Thanks!
Looking at 6 Integer values...say N7:0 - N7:5. Need a clever way to find the Minimum and Maximum values from this group. Better yet would like to...
6,328
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
104
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
110
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
102
