SLC 5/05 Panelview and Inview Display Setup
Jun 2011
Gympie
Hi there,
Im a bit new at this stuff but ill try my best.
Ok atm i have an SLC 5/05 OS501 1747 L551B/C IP address 10.0.2.6. On channel 0 i have a Panelview 600C touch 2706-T6C16 DF1. It is node 1 and the SLC is node 2.
I am wanting to add an Inview Display 2706-P22R. I am wondering how to do this without buying another adaptor etc. I already have a 1747-DPS2 port splitter and was wondering if i can use this? If so how do i set it up? If not what are my options?
Thank you
I no find the 2706-T6C16 datum,if your 600c have an EtherNet Rj45 ,I advice you buy the HUB(I used the model SPIDER 5TX [FONT=宋体]Hirrschmann)[/FONT],the 600C and SLC 5/05 via the Ethernet commuinctaion,then 2706-P22R by the RS232 contact the SLC 5/05, if your 600c no rj45,you only use the 1747-DPS2
Good evening. I am trying to get a SLC 5/03 connected to a Panelview Plus 7 Standard using a Moxa Mgate EIP3170 and I am not having much luck. I...
533
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
686
I have an SLC 500 i'm trying to connect to a Panelview C600. I connected the SLC500 to the Panelview view an ethernet cable and it immediately...
1,225
Hello, I have been asked to update a really old system. It has a 1747-L542 (SLC 5/04 32KB) and a 2711-T10C8 (PANEL VIEW 1000). I have the...
1,696
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
5,038
