SLC 5/05 Pass Through to 485 PV
Bob8417
Dec 2008
Wilkes Barre, PA
I have a problem with passing a PanelView program through the Ethernet port of a SLC 5/05 to a 485 PV. Here is the kicker, I had the Pass Through working a couple of weeks ago and did a couple of downloads to the PV. But now I can only upload the PV program using the pass through. I tried to do an immediate download of the upload but it keeps choking at the verify terminal compatibilty. I spent several hours tweeking my pass through setup but it seems fine.
I would try and use compact flash to transfer the PV program but I can't find a local store that has an old CF and pcmcia adapter on the shelf. I can mail order a flash card but I sort of need it now, as usual.
Any gurus out there have any ideas?
Bob
Why is it now working??
Update...I tried another upload/download to the PV today using pass through and it work right off, in fact I've make several downloads today without any problems. I didn't make any changes to my applications or setups between failure and success. I'm happy it worked but I don't like not knowing why!
Perhaps because you restarted your computer. I've never figured out why but my RSlinx KT driver NEVER works if my computer has been running for awhile. A restart fixes it.
Hi everyone. My plant's about to move some equipment to our sister plant and I've been asked to take some back-ups of the PLC and HMI programs. I...
1,963
Currently I'm running the following applications. WinXP SP 3 RS-Linx 2.52 RS-Logix 500 8.00 Panelbuilder 32 Version 3.82 I'm trying to download...
18
12,022
I have a system that operates with one PV300 (near operator station) and a ML1200 in a panel some distance away communicating using DF1 over...
4,790
I'm trying to set the pass through up on a SLC 5/05 that is connected to a net work of SLC 5/03's via DH485 .Now I've got the Routing table set (I...
13,035
Is it possible to do program upload/download across SLC channels 0 and 1?
8,817
