SLC 5/05 to Micrologix
pauly
May 2002
South Wales,U.k
244
If I wished to connect a Micrologix to a SLC 5/05 via Ethernet, and hang a Schneider Magelis HMI on the same Ethernet network, what might be the pitfalls in doing this? The SLC 5/05 is existing and the Micrologix will just act as a sort of remote I/O via the MSG commands.
Thanks in advance for any replies
Does it for me Pauly! We regularly connect ML1100/1400's to 5/05's and use the Magelis HMI's on top!
The Vijeo Designer is fairly intuitive and is relatively straight fwd to set up drivers for AB...
Hope this helps.
Rob
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
127
I'm attempting to read about 5 different PLC's and storing their data in a CompactLogix 5380 where I can manipulate the data I need. I am having...
19
4,079
Hello, I am currently trying to use a micrologix 1100 to read data from 7 SLC 5/05's and 3 Control Logix. I am only needing one word from each...
3,612
Hi everyone! Hope everyone is having a great day. I just started out with PLC’s and by that I mean I was trying to understand how things...
6,532
I have 5 SLC 503's that I want to network to a Micrologix 1100. All 503 CPU's have their channel 0 occupied so I need to use channel 1. Is this...
3,129
