SLC 5/05 to YET XtraDrive Serial Comm
joel t
Guest
J
I am having problems communicating from an AB SLC 5/05 using a ProSoft MVI46-GSC communications card to a YET XtraDrive. Has anyone ran across this problem before. Any information would be very helpful.
Thanks,
Joel T.
TD - Yes, I have set the lengths and I get information out of the MVI module (I used HyperTerminal to check). However, I cannot get the information to the drive. When using ASCII do you need to reverse the bytes as they come in?
Thanks - Joel
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
91
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
103
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
80
