slc 500 fault
eng_ehab
Mar 2005
cairo
21
dears , i have a slc 500 4/20b processor
the processor obtained a fixed red fault
after few times of power down and up the fixed red fault becomes blinking
and i cannot make a communications
processor completely halt
i trying to replace battery ..
replace rack
replace power supply
cable communications
but no one work
anyone help please
Try this procedure to reset the processor :
1. Remove power from the SLC 500 power supply.
2. Remove the processor from the chassis.
3. Disconnect the battery by removing the battery connector from
its socket.
4. Locate the VBB and GND connections on the right side of the
motherboard.
5. Place a small bladed screwdriver across the VBB and GND
connections and hold for 60 seconds. This returns the processor
to the initial factory conditions.
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,023
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,813
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
1,140
Dear All experts, I have one old PLC Rockwell SLC 500 5/03 and its serial port (RS232) port is not responding on RS232 DF1 driver. I dont have any...
18
4,149
I am getting the following error on my PLC and I haven't experenced this kind before. What should I do? I can't find that error code online. We...
3,136
