SLC-500 program lost rungs
bright676
Nov 2012
va
494
A few months ago we had a issue with a 5/04 not working properly and when a compare was done it was found to have a rung missing in the 5/04. It was reloaded and end of issue until last week when it happened again but with a different rung missing on the same program. Reloaded the program and all is good.
I know that the system was not shut down and the the 5/04 battery is good as it is about 1-1/2 years old.
Does any one have any ideas as to where to start with the troubleshooting?
Is there an EPROM installed? Check the status file for memory and how it can load if installed. This is all going from my memory.
HTH
Probably not relevant unless someone was trying an online edit: (but maybe??)
I had a problem losing a rung repeatedly- but only when doing an online edit. Then when I went offline and went to verify the project I then got an out of memory error.
Checking the processor status turns out there was only 3 bytes of RAM available, and not enough for a copy of a modified rung - so the original and the copy were lost.
Hi all I have a SLC 5/04 with a BAS module sending print data to a dot matrix printer. In the Basic program in this module, there are what...
1,923
Good Evening , I would like to test some message instructions , and other modifications in a SLC 500 5/05 Processor in the office without 2...
1,966
Does anyone know of a free program I can use to upload the program from an AB SLC 500 Fixed and read the error code? I don't want to do any work...
1,583
Hi, I am trying to integrate my system with a Rockwell SLC-500 PLC. I have the program for the Rockwell PLC with me. I have downloaded the...
3,154
Good Morning , How do you replace the battery on a SLC 500 CPU without loosing the program , since you need to remove the CPU , and the...
12,063
